#83162 by Mark F. Madura
Thu Aug 22, 2024 4:49 pm
Dear BETA Testers,
I'm pleased to announce DataCAD 22.02.19 Release Candidate 2 is now available for testing.
Update Installer
DataCAD 22.02.19.02 Update Installer
Full Installer
DataCAD 22.02.19.01 Full Installer
DataCAD 22.02.19 RC2 Fixes:
• In the previous update, the dimensions of the page in new PDF generated documents was changed from being set to the printable area of the selected printer to the selected paper size. When printing directly or from the preview, this had the unintended effect of shifting the paper by the device’s offset amount. This has been corrected.
• Corrected a memory leak related to o2c texture bitmaps created during o2c object generation that could result in significant memory usage when launching the Object Viewer from a large model that contains a large number of bitmap textures. Repeated launches of the Object Viewer under these conditions would result in a failure to create the object due to insufficient memory. Restarting DataCAD was the only way to restore the available memory.
Misc
• The progress indicator dialog for o2c file generation now indicates the current material being processed, and the total number of polygons generated for the object is displayed on the error toolbar.
• The polygon count for the o2c file is now displayed in the Info dialog in the Object Viewer available from the right-click context menu.
